just wondering
Especially if it only "acts weird" when the car is hot. Thats because the oil thins out when the temp rises.
If you feel there really might be a problem, hook up a mechanical guage and verify the pressure. This will eliminate the guage, wiring and sending unit as suspects.
From there if it's still a problem, you can go on checking the oil pump, bearings, etc.
How many miles? The guages aren't so acurate, I'd be willing to bet there's not much of a problem. GM sped says you should have 10psi for every 1000 rpm.
Good luck!
