shiming up the rockers, why?????????
Old Dec 6, 2007 | 09:00 PM
SatisTraction's Avatar
Default shiming up the rockers, why?????????
I just bought a used set of heads and there were some shims under the rocker rail. why would anyone do that? would it make up for milling the head?
Old Dec 7, 2007 | 01:39 AM
PREDATOR-Z's Avatar
It is to adjust geometry (center wipe pattern on valve tips)
Old Dec 7, 2007 | 04:36 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Its all about the valve train geometry. on other cars with adjustible rockers, ive seen then put shim under the spring, no more then 0.040" or put valve stem caps to get everything dialed in.
Old Dec 7, 2007 | 11:11 AM
JPH's Avatar
JPH
it effects geometry, which in return effects wipe pattern and preload.
Old Dec 7, 2007 | 05:18 PM
vettenuts's Avatar
I would double check them personally, but it sounds like someone spent some time setting up the valve train. From what you typically see, that is a rear occurrence.
