Honing cylinders
Old Dec 7, 2007 | 08:33 PM
Almostryan3's Avatar
Default Honing cylinders
Block rebuild on a block that had 130k miles on it. Wanted to go in with a honing stick to re etch the cross etchings, I'm not sure how much material this will take off and I want to re use the stock pistons. Question is will I have to use bigger rings or will stock size suffice and not cause any problems? Thanks in advance.
