Oil pump?
Old Dec 9, 2007 | 04:50 PM
GTO8522's Avatar
Question Oil pump?
Everyone,
What is the stock oil pump on the 04 gto? is it the ls2 pump? Reason asking is I bought a cam shaft package and a comp cam timing set.. and I know it is usually recommened to get a heavy duty oil pump. Is the stock one sufficent? The shop I'm going to recommened a melling heavy duty oil pump... for 139. what should I do?
Old Dec 9, 2007 | 05:22 PM
HOSS Z28's Avatar
use stock
Old Dec 9, 2007 | 07:56 PM
GTO8522's Avatar
roger that. thanks for the info man. why would they want me to change it? just to make more money huh?
Originally Posted by HOSS Z28
use stock
Old Dec 9, 2007 | 10:35 PM
massls1guy's Avatar
I think it depends on how many miles you have on the motor. When you have it all apart it's easy to swap the pump out. I just swapped my oil pump when I did my cam but I have 110k miles. If you have low miles I would leave it alone.
Old Dec 9, 2007 | 10:52 PM
Da Swami's Avatar
I doubt the shop is trying to screw you over; the only thing they'd be able to charge for is the pump itself because the labor is already covered with the timing set (have to take the oil pump off anyway).
It's good insurance, but not always necessary depending on the circumstances like massls1guy said.
Old Dec 9, 2007 | 11:54 PM
Daryn's Avatar
Formerly darynC-10/23/10
i have 100k on my car with a t-rex and my stock oil pump is working just fine..
Old Dec 10, 2007 | 05:35 AM
GTO8522's Avatar
thanks for the info guys. I'll keep the stock oil pump on. can't wait to get everything installed and tuned.
Old Dec 11, 2007 | 02:04 PM
DMONEY06's Avatar
i got a melling pump
