Strange harmonic vibration- HELP- getting worse
Does the trans shift and lock up well?
BTW,you are using an ASP pulley or stock or heaven forbid an SLP POS pulley.
Went out and drove the car at different RPMs in different gears -at just about every gear the vibration is pretty wicked at about 2500 rpm- it's really bad in 3rd. The vibration is still there in PARK at 2500, 3500.
I was thinking about a couple other potential reasons for the vibration (by the way it seems to be getting worse):
1- When I bolted the trans up to the motor, there was .250 between the converter mounting pads and the flywheel. I made up some .160 thick washers to bring the space into spec. I recall that the converter has a smaller diameter in the center that slips into the center of the flywheel. I wonder if the spacers are thick enough that there is no engagement on the pilot. That would mean that the three converter bolts are providing the alignment- which may be causing the vibration as the flywheel bolt holes are oversize and allow for some slop. I was thinking of just trying some .063" washers to see if that helps.
2- Could this just be wicked exhaust resonance? I would think that if there was an alignment problem between the converter & flywheel that the vibration would get worse with RPM. but it doesn't. It is the WORST at about 2500-3000 rpm in 3rd.
3- Is it normal to have realtively heavy vibration like this with a trans mount? should I just put the stocker back on?
4- Is the trans messed up causing the vibration?
The steering wheel will vibrate (not totally unruly, but noticeable), but the heaviest vibratino seems to come from the trans tunnel area. It's hard to tell though if it's trans or motor.
We'll see though- I'll take em out and drive it once or twice and see if that's it.
I have a similar, problem. I put in the SLP aftermarket dual/dual. I couldnt trace it down. To my surprise, after immense research, and after talking to a certian chief engineer, in person, that will remain nameless. I have traced my problem down to the muffler. apparently if one of the welds breaks inside the muffler, one would get a wierd harmonic vibration that comes and goes that rattles most of the pipes. I put it in a lift and tighned everything down, the o2 seosors were taped down with aluminum tape (the covers are loose and rattle) and took a rummer mallet, and tightening down everything. A broken muffler baffle would cause the coming and going of a vibration
to test to see if one of the baffle welds went south use this complex procedure
1) get a heavy hammer.
2) get duct tape
3 When exhaust is cold, tape heavy hammer to muffler.
4) This can only done till exhaust get hot (tape glue will melt) start car, and rev the car to the RPM wher the vibration is the worst. If you notice a RPM difference where the harmonic vibration starts and stops, this means one or more welds in the baffles are kaputski.
idea is this, changing the mass of teh muffler, will change the harmonic properties of the muffler, when it has something wrong in it that causes a harmonic vibration
let me know if this helps you
I took the washers out from between the converter & flywheel, made sure the trans mount and crossmember were tight, and even tried the heavy hammer test- no help.
I'm thinking it's eiher just harmonics in the exhaust note, or the trans (this new trans has been problems from day one).
Ryan
I have something very similar going on right now... I've verified that nothing is touching the exhaust, but I didn't think about a baffle in the muffler possibly causing it.
One thing I plan to try, tonight, is to remove the belt(s) and see if the vibration still occurs ... obviously not driving it around much, if any. I'm keeping my fingers crossed that its one of the idler pullies or something simple to replace. I also don't like the thoughts of having to get a new 4" flowmaster muffler
I took the car to speed inc. and they said that they didn't notice anything
. Motor mounts look good as far as I can tell.
I figure over the winter I'll pull the converter and send it back to precision to check balance and have new u-joints installed.
This is an old thread.....did anyone ever resolve this?
