06-07 LS7 cam in a LS1
Old Dec 15, 2007 | 05:54 PM
PKC-Z71's Avatar
Default 06-07 LS7 cam in a LS1
Thinking about going with a stock 06-07 LS7 cam when I install my ported 5.3 heads on my 99 Z28. Just wanted to get some feedback if anybody else here has done that...I figured it would still have a semi-smooth idle that way and not lose a whole lot of low-end torque either. Thoughts?
Old Dec 16, 2007 | 10:04 AM
Old SStroker's Avatar
This should bring some interesting comments. I suggest you compare the design of the LS7 heads to the LS1/6 cathedral port heads before making a cam decision.
Old Dec 16, 2007 | 10:23 AM
Hennytime's Avatar
im pretty sure it cant work, something about the cam sensor. maybe not. either way should be interesting to see, ls7 cam profile is like the tr stealth cam
Old Dec 16, 2007 | 11:51 AM
jed.only's Avatar
i thought about this one earlier this year. i hear it can be done. i hear it has been done. i just havent seen any concrete results one way or the other.
Old Dec 16, 2007 | 08:12 PM
5.3LJimmy's Avatar
I'm pretty sure the LS7 cam doesn't have the cam sensor provision on it. The cam sensor is in the front cover like the LS2's.
Old Dec 16, 2007 | 08:38 PM
Disturbed Bird's Avatar
just get a ls1 cam cut like the ls7
Old Dec 16, 2007 | 08:58 PM
Asmodeus's Avatar
To add along these lines,
Look at cross section, runner size, and I/E flow ratio of the 2 different head styles, and the valve events they require for the power band you're looking for.
Old Dec 16, 2007 | 10:48 PM
Now these are some interesting comments. More than I expected here. Keep thinking like that!
 Michael S. Palmer
Old Dec 16, 2007 | 11:26 PM
PKC-Z71's Avatar
The reason I asked is because I have a chance to buy a stock LS7 cam CHEAP from a friend of mine who's having a custom cam done for his '06 Z06.
