Cam trouble!
Old Dec 16, 2007 | 03:21 PM
lsxcamaro's Avatar
Default Cam trouble!
Newly acquired 2000 camaro ss. Thinking of adding ported and polished L92 heads and cam. But I want to have a cam with my own specs. If anyone has any info on how to do so that would be greatly appreciated!
Old Dec 16, 2007 | 03:24 PM
jed.only's Avatar
wont work with Ls1.
LS1TORQ's Avatar
Somebody correct me if I'm wrong but L92 heads DO NOT bolt up to LS1 blocks. They will only work on the 6.0L blocks. As far as custom cams talk to Patrick G search this name and he does a custom cam program that is stellar. He knows his ****.
Old Dec 16, 2007 | 03:25 PM
jed.only's Avatar
they bolt up, but the valves will be uber close to the edge of the bore.
Old Dec 18, 2007 | 01:33 PM
lsxcamaro's Avatar
Wow feel like a real mustang driver now! The way it reads in gm high-tech is that you just need the L76 intake to mate them together. I didnt know it was only on the ls2(6.0). I apologize! I trying to go with a streetable setup to yeild about 450+ hp. With mean chop of an exhaust note. How about air flow research?
Old Dec 18, 2007 | 02:01 PM
Disturbed Bird's Avatar
go with trickflow 215's
Old Dec 18, 2007 | 02:02 PM
or looking to keeping a budget look at patriot performance stage 2 heads
Old Dec 26, 2007 | 03:31 PM
98LS-WON's Avatar
Unless you are an engineer or race for a living, let the pros design the cams. There are many proven cams out there for whatever application you have.
Old Dec 28, 2007 | 04:33 PM
bad6as's Avatar
hey 99ls-won do you have a ls6 intake on your car with thoes numbers?
