Vacuum leak driving my insane
Like I said it surges pretty bad and has a hanging idle when driving.
I dont know what else to look for. Is there an easier way to check for a vacuum leak?
My idle was hanging pver 3k rpm at times. I kept looking for vacuum leaks and dumped an entire can of starting fluid and carb cleaner all around the manifold and vacuumm lines. I didn't spray right on the TB cuase I figures it would just enter into the intake side. Well when I went to check all of the manifold bolts and then the TB I about chit when the three throttle body bolts were still only hand tight. Now the throttle body I just missed when I was assembing, but I was surprised when I checked the intake manifold bolts that I could get another turn on them after I had torqued them to spec on assembly. I likely overtightened them now since I was paranoid about vacuum leaks and trying to chase my tail for a week.You can also plug off the PCV and Evap lines with vacuum plugs to eliminate them as leaks.
