Can I mill my heads with this cam?
Old Jun 27, 2003 | 03:16 PM
quickWS6's Avatar
Default Can I mill my heads with this cam?
My cam is a 227/227 .599/.599 on a 110 LSA. Can I mill my heads .030" safely without worrying about piston to valve issues? How much power does this usually pick up and what is the normal cost of it?
Old Jun 27, 2003 | 04:12 PM
2001CamaroGuy's Avatar
Default Re: Can I mill my heads with this cam?
probubly.......call the company that makes the cam and ask them.
Old Jun 27, 2003 | 04:28 PM
Smoke_Ford's Avatar
Yes, although .030 is the max you can go with that choice of cam.
Old Jun 27, 2003 | 05:55 PM
quickWS6's Avatar
Its a Comp cam, by the way. What does everyone else think?
Old Jun 27, 2003 | 06:04 PM
it looks pretty fun....should really lump....
Old Jun 27, 2003 | 06:16 PM
quickWS6's Avatar
Yeah, it lopes pretty good, especially since I'm running a x-pipe dumped before the axle. The cam is already in the car, I'm just changing heads for 987 springs and some minor upgrading.
Old Jun 29, 2003 | 05:42 PM
needmoremoney's Avatar
With my 228/236 571.602 111LSA cam, and my first set of SII 5.7 heads milled .30, When I clayed it, the valves clearly hit th piston. Switched to 5.3 heads milled .005, I had .85 clearance. So if I was you, CLAY IT!!
