What length pushrods with this combo?
Old Jun 27, 2003 | 03:18 PM
quickWS6's Avatar
Default What length pushrods with this combo?
I'm gonna go back into my motor soon and upgrade a few things. I want to make sure I get the right length pushrods for the preload on my Comp R lifters. Here will be my valvetrain:
Yella Terra 1.7 roller rockers
Comp 227/227 .599/.599 110LSA cam
Comp R lifter
Comp 987 springs
heads milled .030"
Anyone know what length pushrods I will need? Thanks!
Old Jun 27, 2003 | 03:49 PM
Cal's Avatar
Cal
Default Re: What length pushrods with this combo?
I'm guessing the the stock 7.400" pushrods will work since your heads are millled 30 thou; should cancel out the small base circle on that big cam. You get shims with the Yella Terra's also, that gives you a little more flexibility.
Old Jun 27, 2003 | 04:00 PM
jmX's Avatar
jmX
I second the guess. 7.400" sounds good.
Old Jun 27, 2003 | 04:10 PM
2001CamaroGuy's Avatar
stock 7.400"
most aftermarket cams have a 0.030" smaller base cyrcle (would need a 0.030" longer pushrod)
heads milled 0.030" would need shorter pushrods
7.400" - 0.030" + 0.030" = 7.400"
Old Jun 27, 2003 | 04:15 PM
BLUEBYU's Avatar
I guess that is why I had to use the shim w/ the YT rockers...I am milled .015? Does this sound right?
