Help choose cam plz
I DEFINITELY want a nasty lope. I believe the 4.10`s in the rear will make up for any power missing down low correct? Can I go over .600 lift and be "safe" as far as motor without blowing it in 5k miles? Thanks for all the help as im a CAM NOOB.
If you want to set long term goals the trex is great, but with heavy cars and a improper suspension/gearing setup it is going to equal an unhappy person.
I personally had a trex and loved it but the car was a track car and was setup for it. I see to many big dyno numbers and poor track times.
