Valve cover removal
Old Dec 21, 2007 | 05:34 PM
ssheets's Avatar
Default Valve cover removal
Can you remove the valve covers without taking off the coil packs. This is an 02 car. I just want to check my rocker bolts, but the coil packs are a PITA.
Old Dec 21, 2007 | 05:53 PM
Xtnct00WS6's Avatar
Nope....the coil pack bracket will prevent you from getting to the valve cover bolts.
Once you get them out....it's a great idea to leave the bolt in the very back out. You don't need it and it's a real pain!
Old Dec 21, 2007 | 07:06 PM
ssheets's Avatar
Yeah, it wasn't that bad. Took a little more than a half hour to pull the driver's side off and put it all back together. I just wanted to make sure my rocker bolts were tight and they are. I only had a 1/$ drive on em, but they wouldn't budge...which is good as I didn't break the set on the loctite.
