Head milling questions...
Old Jun 28, 2003 | 10:14 AM
MOTRUBL's Avatar
Default Head milling questions...
If I had a set of 5.3 heads milled ".030 could I still use the stock pushrod length and rocker ratio without getting into a bind or getting too close to the piston? Or would I be better off milling a 5.7 head??
Old Jun 28, 2003 | 11:02 AM
BigTex's Avatar
Default Re: Head milling questions...
Piston Valve clearance should be the same betweent the two types of heads. If you have a large cam, you should be OK with the stock length pushrod with .030 milled on stock heads. If you have a valve job and different valves, you might need a different size pushrod, but you should ask your head porter.
