Cam for TEA TFS Heads
Old Dec 23, 2007 | 01:54 AM
SOMbitch's Avatar
Default Cam for TEA TFS Heads
I want a good DD with the most power possible. Consider I will run on stock 98 rod bolts for now. It will will see the track 3-4 times a year but not hardcore. Strano handling package too. 68K miles.
Performance mods I will have:
LS 6 intake (with egr)
PP throttle body
Lid
Hooker Super Comp SS headers
Gutted Cats
3" Hooker catback
Stock 28.5 hr. injectors /fuelpump (for now)
underdrive pulley
323 gears
A4 w/ 3400 stall
These heads have great low and mid flow numbers and that is why I finally decided to pony up a little extra $$ after a lot of debate. Eventually I hope to upgrade the intake to a fast 90/90 or the new upcoming Wiend combo I'm sure you have heard about. Thanks for your opinions!!!
Old Dec 24, 2007 | 09:41 AM
Top Fuel's Avatar
if your staying with the small stall and small gears, I wouldnt go too big on the cam. I'd say the best bet would be to go with one of the trick flow cams designed for the heads. And they're cheap as well
Old Dec 24, 2007 | 03:28 PM
3.4camaro's Avatar
I have TEA TFS heads and their Stage III cam. It's nice. 6th gear is nice all the way down to about 1000 rpm before the engine gets pissed.
Old Dec 24, 2007 | 03:32 PM
bad6as's Avatar
with that stall, a low 230's cam would be great with thoes heads
Old Dec 24, 2007 | 06:32 PM
RedDemonLsX's Avatar
With a Torquer v2 cam 232/234,TFS 215 heads,and a Yank PT4000 stall i made 430whp and 405wtq unlocked.If had to do it again i would have went bigger but the combo sure does scream
