TREX and .040 Cometics....will it clear?
Old Dec 23, 2007 | 08:50 PM
Slow 346's Avatar
Default TREX and .040 Cometics....will it clear?
Stock shortblock......stock heads.....TREX cam.....will I be ok swapping to an .040 head gasket to bump compression or will I have PTV issues?
Old Dec 23, 2007 | 09:14 PM
6-Speed Terror's Avatar
if you have stock heads/block you should be ok even with stock gasket.
Old Dec 23, 2007 | 09:23 PM
Slow 346's Avatar
Correct....but I wanna run a thinner gasket than stock.
Old Dec 23, 2007 | 09:27 PM
slick1851's Avatar
I would fly cut the pistons...
Old Dec 23, 2007 | 10:41 PM
418redz28's Avatar
the .040 will not work. u barely have any clerance the way it is.
Old Dec 23, 2007 | 11:38 PM
chuckyt1's Avatar
Flycut it...
Old Dec 24, 2007 | 12:36 AM
PREDATOR-Z's Avatar
Unlikely to fit
