rocker arm question
Old Dec 27, 2007 | 07:50 PM
curtisad's Avatar
Default rocker arm question
Will the yella terra's or harland sharp rockers gain me anything with my cam setup? I have stock rockers in there now.
Old Dec 27, 2007 | 09:04 PM
Zitty'sZ's Avatar
Maybe a few ponies if your lucky , think of them more as a stronger reliable part than stock .
Old Dec 27, 2007 | 09:08 PM
vettenuts's Avatar
Correctly set up, the Yella's will gain you a narrower wipe pattern and much less valve guide wear. Worth it in my book.
Old Dec 27, 2007 | 10:22 PM
SOMbitch's Avatar
Harland will rebuild your stockers and upgrade them so you don't have to worry bout the needle bearing issues for I think $225. Just a suggestion. It's how I'm gonna go soon.
Old Dec 28, 2007 | 11:00 PM
Gregg 00SS's Avatar
What would be the benefit of just rebuilding your stock ones vs going with new aftermarket ones? Simply a cost thing or are the stock rockers good enough with the exception of the needle bearings, which I have had a problem with.
