How to attach 98 PCV system to 99 valve covers??
Old Jun 29, 2003 | 10:11 PM
theblur98ss's Avatar
Default How to attach 98 PCV system to 99 valve covers??
I have a 98 pcv system and I just got center bolt valve covers for my new heads. The PCV fitting is differant on the driver's side from my old perimeter valve covers. Do I need the 99 and up pcv system or can I get a fitting to adapt?
Old Jun 30, 2003 | 06:44 AM
2001 Pewter WS6's Avatar
Restricted User
Default Re: How to attach 98 PCV system to 99 valve covers??
Why didn't you get the LS6 valley cover setup??? I will check to see if I still have my old setup. I switched when I rebuilt the motor. You can have it if I didn't throw it away...
Old Jun 30, 2003 | 04:12 PM
Ditch Digger's Avatar
I ran into a similar problem when I recently installed my TEA heads on my 98'. On my old valve covers I had a PCV connection on both valve covers plus a second port on the passenger side valve cover that connected to the throttle body. The new valve covers only had one pcv connection on the drivers side and no connection on the passenger side except for the front port that connected to the throttle body. I did not see any way to use my old PCV hoses so I just bought a plug for the drivers side and followed jmX's instructions for installing a LS6 pcv system. It was very easy to upgrade and only cost me about $60.00.
Old Jun 30, 2003 | 09:14 PM
Doesn't the block need to be ground somewhere for the ls6 system?
Old Jul 1, 2003 | 07:35 AM
Yes, but if you have a dremel it only takes 10 minutes or so to do it.
