Question about my 427
Old Dec 29, 2007 | 11:34 AM
mohammed_k81's Avatar
Question Question about my 427
With a proper tune this should not be a problem with 98 octanes?
cranck shaft callies 4.000
rods H-PEM eagle 6.125
piston je pore 4.000 cerameck coated dome volume +10 custom
gaskets cometic pore 4.160 thickness 61
heads afr 225 cc flow 350 2.080 1.060
oil pumps slp
pore 4.125
strock 4.000
cylinder 8
piston volume + 10 dome
heads 72
gaskets th. 0.0 61
= cui. 428
= liters 7.01
= Compression 12.59
Old Dec 29, 2007 | 01:17 PM
PREDATOR-Z's Avatar
Originally Posted by mohammed_k81
With a proper tune this should not be a problem with 93 octanes?
oil pumps slp
pore 4.125
strock 4.000
cylinder 8
heads 72
gaskets th. 0.0 61
= cui. 428
= liters 7.01
= Compression 12.59
What is your dynamic compression, I run 12:1 on our 98 Octane (dubai) with no issues.
What is your piston to deck height value (in or out of hole and by how much)
Also I would run TR6 or similar 1 step or 1.5 step COLDER plug gapped at .035>.040
Old Dec 29, 2007 | 07:26 PM
Beast96Z's Avatar
I show your SCR closer to 12:9:1 instead of 12:5. No way I would trust 93 at 12:5, much less 12:9.
Old Dec 29, 2007 | 09:43 PM
ssheets's Avatar
Well it's nice to have Middle East tech support.
Old Dec 29, 2007 | 11:01 PM
Schwanke Engines's Avatar
LS1TECH Sponsor
93 PON or 93 RON? Big difference in those two fuels. If it is not PON, then you need to find the average of the RON and the MON. Over here, we use PON exclusively. I know some overseas stuff is only RON, so be carefull.
It would still be iffy even on 93PON. You would have to have a really conservative spark call. It sounds like a great combo for E-85, but I am 99% sure that isn't available to you.
Old Dec 30, 2007 | 12:48 AM
PREDATOR-Z's Avatar
98 Octane here (premium pump) is equivalent to 94 Octane US standards.
it is good sh*t. As i mentionned I run 8.9 DCR, 12:1 SCR, TR6 plugs and that pump stuff and i can still shoot 100 shot nitrous with no knock. I do have a tight quench at .035 though and almost 0 oil burn contamination. 26* max spark advance
Old Dec 30, 2007 | 02:18 AM
So i guess ill just have to try it at the dyno and make sure i get some TR6 sparks plugs
Old Dec 30, 2007 | 03:03 AM
PREDATOR-Z's Avatar
Yaeh, just start with lower spark advance and a bit more fuel the adjust as necessary.
I would say start with 24/25* range and increase a little at a time. Once you get knock reduce by 1* and that should be the range of operation. If it detonates too much at low timing, then add race fuel and monitor change.
just be careful, mistakes at WOT can be costly.
Old Dec 30, 2007 | 04:45 AM
Talking
Thank you for the all the information I appreciate it in the next 2 weeks ill post what happens with me am just waiting for some parts to come throw from the states
