quest for more compression w/o pvc problems.
Old Dec 31, 2007 | 06:19 PM
92slowmaro's Avatar
Default quest for more compression w/o pvc problems.
ok i know this gets asked alot soo. im going to be running a torquer v3 cam. will be using some custom ported ls6 heads and would like to run 11:1 compression ratio.
with the ls6 engine its stock at 10.5:1 will that be the same on a ls1 motor?
so i could reach that with a cosmetic gasket. and im going to check piston to valve clearance to be safe but will flycutting be needed?
Old Dec 31, 2007 | 10:18 PM
mike#9's Avatar
It would depend on many variables. What cam, what head gasket, any milling on the heads....etc.
Old Jan 1, 2008 | 12:50 AM
92slowmaro's Avatar
i stated what cam. torquer v3. with stock cc ls6 heads. is it possible to reach 11:1 with out milling?
