Custom cam grind who?
Old Jan 2, 2008 | 04:49 AM
lstvr's Avatar
Default Custom cam grind who?
Hi Guys, i want a cam grind doing for my 383 stroker with dart 225 heads. Can you guys reccomend? Thanks.
Old Jan 2, 2008 | 06:20 AM
KILLERARMY's Avatar
Thunder Racing for 1.....
Old Jan 2, 2008 | 06:31 AM
vettenuts's Avatar
Crane has some new aggressive lobes out, might want to check them as well.
Old Jan 2, 2008 | 07:50 AM
WFOWS6_IL's Avatar
Bullet did mine
Old Jan 2, 2008 | 08:19 AM
bjamick's Avatar
Call Thunder Racing and get PatrickG to spec you out one.
Old Jan 2, 2008 | 08:21 AM
JustAFooL's Avatar
+1 for thunder racing..
Old Jan 2, 2008 | 08:32 AM
WE TODD DID's Avatar
Originally Posted by WFOWS6_IL
Bullet did mine
Bullet does some nice small block and big block chevy stuff! I just built an 18* 434 and used one of their nitrous grinds and ended up making 775 on an engine dyno. There is a lot of hp in a camshaft, and I was very well pleased with it to be a nitrous camshaft.
Old Jan 2, 2008 | 10:12 AM
PREDATOR-Z's Avatar
There is also Ed, he is pretty good, hangs around corvette forum I believe
 Michael S. Palmer
Old Jan 2, 2008 | 10:16 AM
Websy21's Avatar
Thunder racing for the actual work and for reccommendations either Pat G or Predator Z, can't go wrong with either
Old Jan 2, 2008 | 10:44 AM
slt200mph's Avatar
Thunder Racing will have Comp Cams grind the camshaft. The good thing about getting one from TR is that they will give you a cam doctor print out on the cam after they get it back from Comp Cams free of charge. At least the last cam I had them do for me it was free. Patrick G or Geoff at TR can help you spec out the cam for you application.
Old Jan 2, 2008 | 10:47 AM
Websy21's Avatar
Another good point I forgot to mention, TR gives you an exact cam doctor print out
Old Jan 2, 2008 | 10:54 AM
Sigforty's Avatar
Try Futral he uses the dart heads on a lot of combos and probably has a grind that will work great for your setup. I personally got my cam from him for my 383, which had dart 205s.
Old Jan 2, 2008 | 10:56 AM
Rob's Avatar
Rob
The GTO board. And yes, a good cam guy.
Old Jan 2, 2008 | 04:43 PM
JPH's Avatar
JPH
242/248 .624/.590 113+4 is a good place to start.
Old Jan 2, 2008 | 05:03 PM
COD02SS's Avatar
TR gets my vote
Old Jan 5, 2008 | 11:26 AM
lstvr's Avatar
Thanks guys, I have ordered the cam from TR, and Patrick G specced the cam for me. I have gone from 222/224 to 232/236 .625/.629 113lsa +2, i also ported my LS2 inlet today, i'll report back when its been on the rollers, any guesses as to what i should pick up on my stroker 383 power wise?
