oil in intake manifold????
Old Jan 6, 2008 | 05:38 PM
WhiteFormula98's Avatar
Default oil in intake manifold????
Ok so i did the egr removal and i peaked inside the ls1 intake manifold to find a litlle bit of a substance in there.... i dont know if its oil.... anyone know what it could be and it was very little? is this bad?
Old Jan 6, 2008 | 05:39 PM
spookyz28's Avatar
the head is probably cracked some where
Old Jan 6, 2008 | 05:48 PM
massls1guy's Avatar
The LS1's are known for pulling oil from the PCV into the intake manifold. Easiest solution is a catch can, I got this one from thunder racing (sponsor):
http://www.thunderracing.com/catalog...vid=3&pcid=316
I also did the LS6 valley cover mod. It's more involved, I would just do the catch can if I was you. You can read about it here if you want:
http://www.ls1howto.com/index.php?article=18
It all ends up looking like this:
http://www.putfile.com/pic.php?img=7299774
Old Jan 6, 2008 | 06:00 PM
Redlinez's Avatar
Norris Motorsports has the same one along with two others with upgraded fittings for your delight.
Old Jan 6, 2008 | 06:43 PM
well now that i look at it, it isnt thick enough to be oil..... looks more like water or gasoline??? Anybody have ideas on that?
