CR for a stoker
Old Jul 2, 2003 | 11:02 AM
robertbartsch's Avatar
Default CR for a stoker
Visiting "CarMath.com" recently I calculated the compression ratio of a proposed stroker at 15.33 to 1!!!!
Variables were:
Bore 4.0 (stock LQ4 iron block)
Stroke 4.125
chamber = 60CC
deck hieght = 0???
Holes = 8
valve relief = -10CC
Is this correct; How can I reduce the CR to around 10.5 to 1?
Old Jul 2, 2003 | 03:05 PM
ls1290's Avatar
Dumb Ass Vette Moderator
Default Re: CR for a stoker
For that combo, I get 11.5:1 using a 0.054" thick gasket. I have a question or two for:
1) What heads are you using to get 60cc? milled 0.02" 5.3L...
2) -10cc for valve reflief is quite a bit, what size cam are you going to run?
Old Jul 2, 2003 | 03:38 PM
Thx....
60cc combustion chambers are from a SDPC ls6 Lingenfelter ported head that has been milled .055 (the ASA heads that everyone is selling, PACE, SDPC, GMPP, etc.)
Cam for stroker is not known yet, my current cam is 220/220, 564/564, 112 LSA....
...is this cam too small for a 414ci stroker?
Old Jul 2, 2003 | 05:36 PM
BIG PD's Avatar
Thx....
yes it is too small
