Oil starvation?
Old Jan 7, 2008 | 11:52 PM
01'WS6's Avatar
Default Oil starvation?
Just curious, has anybody ran into oil starvation issues or heard of them with LS1's?
Old Jan 8, 2008 | 07:00 AM
s346k's Avatar
ask anyone who has spun a bearing what caused it. typical chevrolet wet sump - feeds the motor excellent - returns to the pan poorly. chevrolet has been notorious about this for like 50 years or something..haha.
Old Jan 8, 2008 | 07:21 AM
vettenuts's Avatar
This is one reason that I didn't buy the Melling pump, I was concerned with this happening. The LS1 puts a lot of oil up top at high RPM.
Old Jan 8, 2008 | 09:13 AM
CamaroZstyle28's Avatar
Im Pulling my motor out now because of oil starvation, I spun a bearing about a month ago .. Can't wait for my 383 tho !!
Old Jan 8, 2008 | 10:08 AM
ls1leadfoot's Avatar
i spun 1,2,7,8 on mine....guy said it was from pump going bad......i always ran mobil 1 5w30 synthetic though
Old Jan 8, 2008 | 11:46 AM
AU N EGL's Avatar
Yes
Seen several cracked blocks do to oil starvation. Mostly back in #7 & #8 do to oil starvation during a high speed sweeping corner on a road course. and valves dropping in the 7 & 8s
Running a quart over helps most of the time. Accu-sump helps all the time. also helps with pre-lubing the block before start up.
Old Jan 8, 2008 | 06:12 PM
ROCNDAV's Avatar
Originally Posted by AU N EGL
Yes
I've been seriously thinking of adding an Accu-sump to my set up. So you only think a 1 qt is sufficient? Not a 2 or 3 qt?
Old Jun 13, 2008 | 10:39 AM
RaceDriver's Avatar
Depends on what do you with your car. For autox and most road courses 1qt should be enough. Try to stay away from after-market pans, though, just use the stock pan. Where would you mount it accusump? In race cars a lot of people install them in the cockpit.
Old Jun 13, 2008 | 02:12 PM
ROCNDAV's Avatar
I've heard of people putting them in the fender area or the front bumper support area. Don't like the idea of a medium fender bender busting something off and losing my oil .
Old Jun 14, 2008 | 05:37 PM
bichin95redta's Avatar
LS1's have been known for oil starvation problems using the OEM-supplied oil pump. Oil is supplied to the cam and main bearings together; i.e., not a priority main feed oil system. Porting the OEM pump helps. Buying a hi-flow aftermarket pump helps even more. Removing the plastic lifter retainer trays, and drilling two, 1/2" holes (1 per lifter) in them will help oil get back down to the pan faster.
Old Jun 14, 2008 | 05:54 PM
joker machine's Avatar
Has anyone else here drilled holes in plastic lifter retainer trays and or heard of this?
Old Jun 14, 2008 | 08:59 PM
OUTLAWZ RACING's Avatar
I heard about it. Some good things some bad. the bad was letin oil dirp out to fast and causing lifter damage. The good was for the really high rpm guys and big oil pumps and psi.
Old Jun 14, 2008 | 09:24 PM
sappy96's Avatar
I have a brand new SLP high flow oil pump I am selling if anyone is interested.
http://www.ls1gto.com/forums/showthread.php?t=248319
Old Jun 14, 2008 | 09:54 PM
2001CamaroGuy's Avatar
heard OF it happening?
I HEARD/FELT it happen (cool noises and strong lurch as the engine tried to lock up)!
With the "stock style" wet sump (ported high flow pump, baffled pan), I managed to spin #7 and #8 on my 388. At high RPM, the oil puddles in the top of the engine and can't get back down to the pan fast enough, resulting in the oil pump sucking air.
It's the reason I'm converting to a 5 stage dry sump system
Old Jun 14, 2008 | 10:12 PM
sappy96's Avatar
how much does a setup like that cost?
Old Jun 14, 2008 | 11:02 PM
Kamin's Avatar
one thing the track guys do (myself included) is run an extra quart of oil. it increases blowby slightly, but seems to help with the starvation (not prevent, help).
im running a thunder ported ls6 pump, and an extra quart. i only run redline (a true synthetic, not like mobil1. i love starting this fight haha).
so far so good. going on about a year now with 500+ track miles ( 5000+ rpm the entire time) and its still going strong. *knock on wood*
Old Jun 15, 2008 | 11:28 AM
$3-$4K
Old Jun 16, 2008 | 01:05 AM
FadedFD's Avatar
There is this one other option you guys should consider. It's a custom baffle made by Improved Racing. http://www.improvedracing.com/produc...3a4784f04e942c
It will probably save your cars from oil starvation during hard driving while running the stock FBody pan. I just picked one up for my LSX RX7 build since I need to use the FBody pan.
Old Jun 16, 2008 | 07:51 AM
sappy96's Avatar
Originally Posted by 2001CamaroGuy
$3-$4K
ouch
O well if you need it you need it.
Old Jun 16, 2008 | 09:32 AM
FadedFD's Avatar
Kamin,
Awesome S14 by the way. I use to have an auto Kouki S14 that was pearl white. If it was 5 speed I would have kept it. Wish I did now that I've discovered these LS swaps
