ls1 durability
Old Jan 10, 2008 | 11:40 PM
greinder03's Avatar
Default ls1 durability
i am purchasing a 2000 z28 with 121,000 miles. doesnt burn oil. would you trust bottom end strength doing ls6 heads and ms4 cam set-up? and possibly 150 shot direct port nitrous?
Old Jan 11, 2008 | 12:38 AM
Asmodeus's Avatar
A compression and leakdown test will tell you what you need to know.
And heads/cam/nitrous on any stock bottom end is not recommended if you want it to live for a while. can it be done? Has it been done? Sure it has. Have people cracked ringlands and spun bearings trying this? Definately a big YES to that one too.
Old Jan 11, 2008 | 01:43 AM
GTObsessor's Avatar
If you're going to get the full potential (or very close to it) out of that donkey dick cam, you're gonna have to spin that motor to the moon (probably upwards of 6,700RPM) and the stock bottom end won't support that for long. As for the spray, I wouldn't, especially not regularly and not a 150 shot. Wait untill u can get a forged bottom end, THEN spray it... hell, then you'll have upgraded rod bolts and be able to spin the motor as high as the MS4 will require for max power.
Old Jan 11, 2008 | 01:47 AM
LSWannabe's Avatar
I would say the bottom end on a motor chasing the MS4's peak would be less durable than one shifting at 6600 or so instead of 7. You could upgrade rod bolts but H/C and spray would put you on borrowed time.
-EDIT- Like he said.^^^
Old Jan 11, 2008 | 07:26 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Depends on prior use/matience, spinning the motor that high to make use of the cam is going to be tough. I'd put a milder cam in it and you will still make great power,plenty of 22X/23X cams out there making good power.
Old Jan 11, 2008 | 05:51 PM
greinder03's Avatar
my goal is to get the biggest cam stock ls6 heads can handle. i am new to this and dont know, what cam would you recommend. i also have a ls2 waiting to go in, so i am just trying to see what kind of numbers i can get out of an ol ls1
Old Jan 11, 2008 | 06:03 PM
Shawn @ VA Speed's Avatar
I got a cam that works great with stock ls6 heads,i pm'ed the specs
