What are my stock heads?
Old Jan 11, 2008 | 11:56 AM
WhiteFormula98's Avatar
Default What are my stock heads?
What are my stock heads called and what would be a good set for daily drivers?
Maybe having them ported?
Old Jan 11, 2008 | 01:33 PM
5.3LJimmy's Avatar
Your stock heads are casting#806 and are known as perimeter bolt heads. You can have those ported if you don't mind the downtime and know someone who's good with a die grinder. But I would look into some CNC ported 5.3 or LS6 heads from one of the site sponsors. If you decide to get new heads you will need to get the 99-up centerbolt valve covers and coil brackets. Are you planning on doing a cam upgrade also?
Old Jan 11, 2008 | 09:01 PM
Asmodeus's Avatar
for daily driving you'll want to keep the runner size as small as possible.
I'd recommend the AFR 205's or the Patriot Predator 200's.
Old Jan 11, 2008 | 09:48 PM
Shawn @ VA Speed's Avatar
put on a set of ls6 heads and intake,good power for cheap
Old Jan 11, 2008 | 10:33 PM
socmguy's Avatar
Restricted User
I agree, mill 'em down a little for a little more compression.
Old Jan 12, 2008 | 10:05 AM
what are the ls6 heads called and with what springs and retainers or whatever should i get?
Old Jan 12, 2008 | 10:16 AM
01ghostwhitez's Avatar
What about a set of dart 205's, aren't they relatively affordable? They would seem to be a good head for a daily driver with (assuming) a mild cam!
