PCV conversion
Old Jan 12, 2008 | 06:40 PM
Ilikeppie's Avatar
ok ok so what if i got aftermarket valve covers similar to slt200mph and kept my stock ls1 valley plate and just threw a breather filter where the cap goes how would that work
Old Jan 14, 2008 | 09:22 AM
slt200mph's Avatar
There are a lot of very nice looking valve covers on the market ... The valve covers that I am using are from GMPP they will be the least expensive of the valve covers that are available...they have no holes or openings in them except for the oil fill hole on the passenger side. You could drill and tap them for some nice AN fittings if you wanted to duplicate the factory plumbing with SS lines and AN fittings..to me that was far to complicated and would still have too much clutter under the hood..I was looking to clean up all that stuff ... so I used the LS6 PVC , LS6 valley cover, and a breather and it has worked out fine for me.
Old Jan 14, 2008 | 09:58 AM
brad8266's Avatar
Originally Posted by Tainted
i vote against running a breather. a pressurized crankcase is best, and without it you may have trouble with the rings sealing amoung other things. its a good system, better than the breathers and thats why its used on modern day cars.
What?? The idea of the PCV system is to alleviate the pressure from the crankcase. Both a PCV or a breather will take the pressure out, the dfference being that the PCV will reroute gases back into the engine to be burned. It keeps th oil cleaner.
Old Jan 14, 2008 | 07:37 PM
INMY01TA's Avatar
I've done it. Not worth it. Still got oil in intake. Skip it.
Old Jan 14, 2008 | 08:16 PM
Ilikeppie's Avatar
thats what im thinkin im just gonna throw a breather on the valve cover
