coolant lines question
Old Jan 12, 2008 | 07:05 AM
Mike Cordero's Avatar
Default coolant lines question
Do the LS1 and LS6 coolant lines are the same? bolts on?
Old Jan 12, 2008 | 07:58 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
If you are talking about the ones running to the heads then yes they interchange
Old Jan 12, 2008 | 06:06 PM
The ones that runs under the intake manifold. thanks.
Old Jan 14, 2008 | 09:42 AM
Any comment at all?
Old Jan 14, 2008 | 03:03 PM
The Hammer28's Avatar
I believe that the coolant lines are different. That's why you have to modify the LS6 intake when installing onto an LS1.
Old Jan 14, 2008 | 03:18 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
The coolant lines under the intake are different.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Jan 14, 2008 | 03:31 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
They're different but so similar that you can use either on either setup. To use the LS1 lines on the 5.3L it will require an ever so slight bend to that line. It's nothing major and it wouldn't crimp it or anything. This is due to a VERY slight different in that area on the head. Nothing serious, run whichever you want. We keep the LS6 pipes/plugs in stock if you want them!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jan 14, 2008 | 07:58 PM
Thanks for your advice.
Old Jan 14, 2008 | 08:31 PM
1320 killer's Avatar
They are different. If you are asking because you are doing a swap to a ls6 you can get the ls6 coolant lines and rear block offs for around $10 shipped on ebay.
Old Jan 16, 2008 | 04:36 PM
Z28/2002's Avatar
you stole my avatar, dick
Old Jan 17, 2008 | 01:35 AM
green28's Avatar
The way I look at it the more of those avatar's running around, the better.
Using the LS1 lines on a 5.3 was mentioned up above. So there is a little bit of modifying involve in this? Reason I'm asking is I gave my LS1 intake and coolant lines to my brother for a future mild 5.3 build, the more info we know now the better.
Old Jan 17, 2008 | 01:54 AM
99mongooSS's Avatar
I totally agree. lol.^ And, yeah they are different but only cus the ls6 doesnt go under the manifold and there are blockoffs for the back.
Old Jan 17, 2008 | 02:07 AM
sorry about that. lol. I seen it and had to have it. I have a lot of them but cant use them here. due to size so I would have to make them smaller.
Old Jan 17, 2008 | 02:15 AM
99mongooSS's Avatar
no dont apologize the more the merrier. lol. Thats my favorite avatar on this site right now.
Old Jan 17, 2008 | 02:58 AM
mine too
Old Jan 18, 2008 | 09:06 PM
Z28/2002's Avatar
It's cool just giving you a hard time
