oil pressure question
Old Jan 14, 2008 | 08:35 AM
bigboy t/a's Avatar
Question oil pressure question
i have a 99 t/a and i was wondering what could be wrong when my oil pressure gage is jumping around the place
question is what could wrong if anything?
Old Jan 14, 2008 | 09:53 AM
bjamick's Avatar
Possible pump fault. Or your guage cluster could be going out..
Old Jan 14, 2008 | 11:58 AM
massls1guy's Avatar
Have you taken your intake manifold off recently? It's easy to damage the oil sensor when you remove or install the manifold. The oil sensor screws into the top of the block right behind the manifold.
Either way I would start by replacing that sensor, it's the best place to start.
Old Jan 14, 2008 | 12:19 PM
SShawn's Avatar
what work have you had done to the car?
Old Jan 14, 2008 | 12:59 PM
99mongooSS's Avatar
Do you hear any other noises like tick and pings?
Old Jan 14, 2008 | 01:08 PM
FRUSTRATED T/A's Avatar
the oil sensor i would say first, then mybe pinched pickup o-ring, or something worse.
Old Jan 14, 2008 | 10:29 PM
SShawn's Avatar
thats what i was trying to get at. if youve had an intake put on maybe you broke the oil pressure sender, or if you have a cam, the o ring on the pump may have been torn.
Old Jan 15, 2008 | 11:07 AM
bigboy t/a's Avatar
car is stock but ill try replacing the sensor first and see if that fixes the problem
thanks for the info
Old Jan 15, 2008 | 12:12 PM
Steve Bryant's Avatar
LS1 Tech Veteran
It sounds like an intermittant electrical connection or a faulty sensor.
Steve
Old Jan 15, 2008 | 12:56 PM
look for corrision in the connector, clean and put dielectric greas in their.
Old Jan 15, 2008 | 01:04 PM
NC98Z's Avatar
When in doubt the only real way to tell is to get somebody to check the oil pressure with an analog guage. Most shops have the piece tapped out and it is fairly easy to check from the location above the oil filter.
Old Jan 15, 2008 | 01:06 PM
Jon@Texas-Speed's Avatar
It could be a ground promblem. I have seen that on several cars.
Old Jan 15, 2008 | 01:25 PM
SShawn's Avatar
if your stock then ide definately check the wiring. grounds and connectors as mentioned, or anywhere the wires may be rubbing against something.
Old Jan 16, 2008 | 04:46 AM
SSMOKIN_Y2KSS's Avatar
faulty sensor...huge cam?
