need help on carb setup
Old Jan 16, 2008 | 01:51 AM
GraphicNature's Avatar
Default need help on carb setup
ok i want to build a stock cube motor with a good set of heads and a big cam with a carb on top so my question is what to go with, i have been looking at either a ms4 or g5x4 cam and either prc or trickflow heads and i do not know about the best carb style intake and its going in a 91 mustang coupe car with a 350 turbo transmission would like to see 10s on motor
Old Jan 16, 2008 | 02:31 AM
wolfy's Avatar
i know the same answer is given over and over, but you should have one spec'd for you. carb vs efi = motor prefers a different cam. all the off the shelf cams are designed for efi, since that's how these motors were produced. by having one spec'd out for your specific needs you will be MUCH happier with the end result, and it's not much more expensive than buying off the shelf.
my $.02
Old Jan 16, 2008 | 01:33 PM
OK who does that
Old Jan 16, 2008 | 02:07 PM
rickyracer25's Avatar
patrick G, Pred Z(but he is not "online")
