comp 1.85 rockers
Old Jan 16, 2008 | 05:27 AM
jkwalkercchs's Avatar
Arrow comp 1.85 rockers
i got a good deal on them are they worth using in my truck motor im building
ported and polished 243s
on a 5.3 block with 11.1 compression
with this cam
Duration at 050 inch Lift: 216 int./224 exh.
Lobe Separation (degrees): 115
lift: 561
comp 918 springs
Old Jan 16, 2008 | 06:29 AM
teke184's Avatar
as long as your ptv clearance is sufficient go ahead.
Old Jan 16, 2008 | 06:49 AM
u lost me ont that one ptv??
wat would the lift equal out to?
wats the max lift on those 918s
Old Jan 16, 2008 | 08:41 AM
DONAIMIAN's Avatar
If they're the comp pro mags and you pass on them let me know. I have a set of the pro mag 1.75's that I want to trade for a set of the 1.85's.
PTV means piston to valve clearance. If the heads are milled and depending on the valve size they could touch.
Lift would be right around .610
Max lift for the 918's are .600 or .625 if you have the newer version.
Old Jan 16, 2008 | 08:49 AM
wat would it be with the 1.75s
Old Jan 16, 2008 | 08:53 AM
DONAIMIAN's Avatar
The lift would be .561
Old Jan 16, 2008 | 08:58 AM
teke184's Avatar
lift...
.561 / 1.7 =.330
.330 X 1.75 = .577
.330 X 1.8 = .593
.330 X 1.85 = .610
i was told with the 918s...even the old ones that i have...max lift is .620 or so. but .610 would be pushing it. may as well spend the $$ and get patriot duals to handle .650
Old Jan 16, 2008 | 08:59 AM
how much would those run me
Old Jan 16, 2008 | 11:17 AM
teke184's Avatar
we have a sponsor list for a reason -------->
you can look it up as easy as me
Old Jan 16, 2008 | 11:23 AM
sorry there i was just lookin for a rough draft estimate not the mrsp for january 08 ok
