rebuilding ls1
Old Jan 17, 2008 | 12:51 AM
1funz28's Avatar
Default rebuilding ls1
how far can the cylinder walls be bored on a 98 ls1, what else should i be looking at doing while i am rebuilding.
already am planing on cam install, oil pump, bearings, seals, gaskets ect. planning on using stock crank, what all can be done at a reasonable price for parts as im going to be doing most of the work?
Old Jan 17, 2008 | 01:08 AM
99mongooSS's Avatar
I think to 3.910 or 908 but I wouldnt go over 3.905.
Old Jan 17, 2008 | 02:10 AM
1320 killer's Avatar
I agree you don't want to maxit out. If you want bigger go with the 6.0 block.
Old Jan 17, 2008 | 02:13 AM
99mongooSS's Avatar
yep. agreed.
Old Jan 17, 2008 | 11:54 AM
1funz28's Avatar
so from what im seeing then if i do a stroker kit then ill be looking at a 383 max or can it go bigger, if i am going to do it then im going to go as big as i can displacement wise!
Old Jan 17, 2008 | 11:57 AM
rickyracer25's Avatar
the biggest is a 39(3/7) it's a 3.905 bore with a 4.125 stroke made by eagle... I
Old Jan 17, 2008 | 02:17 PM
Shawn @ VA Speed's Avatar
if you want big go with a 6.0 block,or if you want more get a ls7 or lsx block
Old Jan 17, 2008 | 02:43 PM
1funz28's Avatar
will the tsp 5.3 heads fit on a 98 ls1, wil the ls6 manifold bolt up to them or is there a different manifold for it! now i am just thinking of over hauling the motor, tsp stage 2.5 5.3l heads, cam.
Old Jan 18, 2008 | 10:54 AM
NassyVette's Avatar
A 98 block should have a 3.898 bore stock, the most GM recommends for a rebuild of the early blocks is a .005 hone. That brings you to 3.903.
Any 5.3 casting will work on a '98 block, its the 98 heads that won't work on later blocks. And the LS6 manifold will also work fine.
Old Jan 18, 2008 | 12:20 PM
1funz28's Avatar
cool i guess that i will have to get center bolt vavle covers and the part that the coils bolt onto? thanks for the input!!!
Old Jan 18, 2008 | 12:28 PM
NassyVette's Avatar
Or you could use the opportunity to relocate the coils under the dash if the clean look tickles your pickle.
Old Jan 18, 2008 | 12:37 PM
EndlessSummer85's Avatar
DO NOT FORGET ARP rod bolts!!!!
Old Jan 18, 2008 | 08:56 PM
1funz28's Avatar
thanks no was already on the list of parts to get!
