timing chain info needed 98 ls1 semi built
As for N-motion, we had another thread on this. N-motion is made for SDPC by JP Performance and it re-branded (hope that's the correct term).
I spoke to Cloyes, they did confirm their upper cam sprocket could be machined for a Torrington, not sure how much that would cost though especially on top of an already expensive timing set.
Not sure which IWIS chain Rollmaster uses, they may have seamless rollers. I also corresponded with Ed Curtis of FTI and he pulled a couple of Ford Rollmasters off the shelf and looked at them. Both had seamless rollers, one was an IWIS Ketten (JWIS) and the other was a Rolon.
Confusion reigns supreme.
Then throw in the normal manufacturing delays and supply problems assocated with parts sourcing and it's really a crap shoot what you'll actually get in the box.
If you look at the chain, where it fits into the sprocket is the roller. The roller sits on a pin that goes through the center of it. On some chains, the roller is one piece like a pipe. On others, they are formed from flat stock and basically bent round which leaves a seam where the two ends join but it is truly not a tube. If you think of something like a carboard roll in the center of paper towels. Seamless would be the roll you get with no paper towels on it. If you then slit it along the entire length, it would still be round but there would a slit (seam) in it.
Your correct, this is what I just got from Rollmaster/Romac:
"Two months ago the business of Rollmaster Timing Gear Sets and Romac Harmonic Balances were bought by Nornda Automotive which is part of JP Performance."
It is advertised as fitting behind stock covers too.
