which underdriven pulley ?
Old Jan 18, 2008 | 10:34 AM
onebad636's Avatar
I need to get one too! Maybe I will join the crowd and get a SLP one.
Old Jan 18, 2008 | 11:21 AM
qwk93ta's Avatar
I have an ASP on my 93 and plan to do the same for my 00 WS6.
Old Jan 18, 2008 | 12:38 PM
EndlessSummer85's Avatar
Originally Posted by Gun5
i want to buy the powerbond but if its gonna slip a belt would rather get SLP
The powerbond has pretty high walls, don't really see how the belts gonna slip. TSP has them for a good price and they have both belts for it too. IMO it's one of the better ones, well from what I've seen and heard.
But no matter what one you get don't forget the ARP crank bolt, holy crap it makes the install a lot easier!!!
Old Jan 18, 2008 | 01:17 PM
DANOZ28's Avatar
are there any neg affects from changing to an underdrive pulley, i heard somewhere that power steering could be affected. any hotter h2o temps or charging issues at all?
Old Jan 18, 2008 | 02:56 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Well, you are turning your accessories slower, so your power steering pump won't be pushing as much fluid (not a bad thing since the stockers push so much anyways), your water pump won't be pumping as much water (but you most likely won't notice an increase in overall coolant temps), and your alternator won't be spinning as fast, and that is something I did notice (I run a fair amount of electronics).
Old Jan 18, 2008 | 03:06 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
Powerbond is a good pulley. I have plenty of them in stock for 209.99
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Jan 18, 2008 | 03:22 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Agreed the Powerbond are nice which we stock. We can also get you into an ASP pulley. They do cost a few bucks more up front but weight a bit less than the Powerbonds do (which is a plus)!
Let me know if I can help with anything on your build. We're glad to help!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jan 18, 2008 | 03:33 PM
billybadd's Avatar
Powerbond here. Walls are tall, havent had an issue on slippage but then again I only spin my motor to 6,600.
Old Jan 18, 2008 | 03:46 PM
Gun5's Avatar
Originally Posted by MeentSS02
You can get their alternator pulley separately in either overdrive or underdrive. I actually use their underdrive alternator pulley with my setup...
I had a Powerbond 25% UD, and now run a full sized ATI Superdamper.
got the powerbond still?
