rebuild suggestions
Old Jan 21, 2008 | 06:23 PM
ss69's Avatar
Default rebuild suggestions
Let's start of by saying this will be my first LS build. My '98 Z has 119,xxx miles on it and was NOT taken care. It will drive all day with 20psi oil pressure constant (fluctuates slightly when revving and driving) but the first time I lay in it to about 5k rpms the oil pressure drops out and I start to hear noises SO..... here I am. Planning a rebuild before I leave the shop that I'm working at so I will have a lift and HEAT! Haha. For the most part all I want is a close to stock build. I've bought some 853 heads(got a good deal) and will have them semi worked and I'm planning on the usual gaskets/seals, bearings, oil pump/pickup screen, rod bolts, and a LS2 timing chain, hopefully no machine work but we'll see once I tear it down. I want to get it back to running as soon as possible when I tear it down as I don't have another car and will be driving one of dad's toys. It won't be a problem doing a LS6 intake or other bolt-ons later as I can do them once it warms up and isn't easier with a lift.
All of that to ask you this: Can you see anything that I am missing? This car won't see any spray, will see little to no street action and will be used as a daily driver. Like I said I can add bolt-ons later. Just want to do the hard part while it's easy and convienent(sp?).
Old Jan 22, 2008 | 07:12 AM
ss69's Avatar
any suggestions?
Old Jan 22, 2008 | 06:41 PM
ss69's Avatar
Or I'll find a short block and build it on the side to swap all at once. Then I'll sell my old engine.
Old Jan 22, 2008 | 07:46 PM
black01_WS6's Avatar
find a lq9 shortblock at a juk yard that runs and put that in, then sell the ls1. you will have more cubes and a iron block will last quite a long time if taken care of.
It is a lot easier to do the machining on the iron block as well.
Old Jan 22, 2008 | 07:58 PM
ss69's Avatar
Lq9 meaning 6.0 liter?
