oil pressure!!
Old Jan 23, 2008 | 09:56 AM
DMONEY06's Avatar
Default oil pressure!!
ok when i start the car its prolly like at 50 then when its warm itll drop to 40 then after i drive it for a while it idles like at 25 30psi wtf??
Old Jan 23, 2008 | 10:01 AM
BLACK2001SS's Avatar
when did you change your oil last and what kind of oil do you use?
Old Jan 23, 2008 | 01:50 PM
DMONEY06's Avatar
i just got the motor rebuilt ran that oil for 100 miles then i just changed it two days ago no leaks anywhere i can see at all i used valvoline 10w30
Old Jan 23, 2008 | 03:21 PM
bczee's Avatar
What kind of clearances did engine builder have the crank and rods bearing at?... what Oil Pump mod's (new, use, aftermarket, ls6, ported, relief spring).
