Got a Question
The question most people are going to ask is why bother with the LS6 cam, when you can get more of a good thing with mild durations and wide LSA's and still retain the stealth afforded by the LS6 cam. A mild Comp XE grind would not impart an excessive amount of valvetrain noise. You could run a 212/218 .558/.563 116+2 cam that still has -17* overlap for a stealthy idle, and would still offer enough exhaust split to work with the spray. The extra duration and faster ramp rates (over the LS6 cam) would make a lot more power overall, and all without hurting the low end response at all.
Not the question you asked, but food for thought...
. I'll consider that cam, though, because I really haven't looked into getting a custom grind.
