Valve spring
Old Jan 23, 2008 | 11:02 PM
Apollo0526's Avatar
Default Valve spring
I have been looking at different springs and i'm unsure of what to go with.
-Comp 921 duals with valve seals, titanium retainers, and spring seats
-Crane Cams Dual Valve Spring Kit
-Precision Race Component Spring Kit
or any others.............
New port and polished heads, going with the trex cam 242/248 .608/.612
Old Jan 23, 2008 | 11:11 PM
5.3LJimmy's Avatar
The PRC springs will be fine for that cam and for the are money hard to beat.
Old Jan 23, 2008 | 11:25 PM
Jon@Texas-Speed's Avatar
The PRC springs would be a great match for that cam. Kit comes with titanium retainers, seats, and seals. Give me a shout or shoot me a PM with any questions or concerns and I'll make sure we get you fixed up with everything you need.
Jon
Texas Speed
Old Jan 23, 2008 | 11:49 PM
02T/A-WS6's Avatar
I would imagine a lot of dual spring good to .650 lift would work for you. I am in the process of purchasing everything for my cam setup and i have been recommended Patriot Gold Extreme dual spring kit which is good to .660 lift. Extra lift will help reduce wear and make them last longer...at least thats my understanding.
http://www.ls1speed.com/catagory.cfm...in%20/%20Heads
Old Jan 23, 2008 | 11:54 PM
5.3LJimmy's Avatar
The PRC's and Patriot Extremes are the same spring with different retainers.
Old Jan 24, 2008 | 10:50 AM
slt200mph's Avatar
manufactured by the same company...same springs...either will work just fine in your applaication...You could use the comp or crane dual springs but they will not do a better job and will cost more than the patriot or PRC ..
Old Jan 24, 2008 | 11:02 AM
99mongooSS's Avatar
Same springs.
Old Jan 24, 2008 | 06:43 PM
Apollo0526's Avatar
Thanks for the help!!
