Cylinder Head Flow ?????
Old Jul 8, 2003 | 10:38 PM
Donovan's Avatar
Default Cylinder Head Flow ?????
I have a couple question about cylinder head flow numbers. I am seeing heads flowing in the 300cfm range and I was wandering if anyone has flowed those heads with the manifold and throttle body on it. This is how my cam grinder wants the flow figures. I have done this on a couple carbed engines and we have seen the manifold and carb cut the flow as much as 20%. So does anyone have those numbers? I would like to put a 6.0L into my 71 Nova and I think this is going to be the best choice.
Old Jul 9, 2003 | 03:11 PM
robertbartsch's Avatar
Default Re: Cylinder Head Flow ?????
...i have some excel tables with flow numbers for many after-market heads....send me an e-mail if you want them
robertbartsch@kpmg.com
the flow number do go down a bunch with the manifold, TB, MAF, air filter, etc....
However, since every head is impacted the same, the flow numbers in the chart are still a good indicator of the flow characteristics of each head...
Old Jul 9, 2003 | 06:29 PM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
Also, I have a spreadsheet
http://users3.ev1.net/~black_ops/hea...s-01-03-03.htm
With all the flow numbers, ls1 and ls6 alos include manifold numbers look in the 4th tab, with and without mainfolds tab...
Should get you close...
Old Jul 9, 2003 | 09:22 PM
Donovan's Avatar
Thanks great info?
