anyone run comp cams XER273HR?
Old Jan 28, 2008 | 01:45 PM
kingsey's Avatar
Default anyone run comp cams XER273HR?
I think it would make quite a bit more power then the 224 cams out there.
224/230 581. 585 114lsa
Old Jan 28, 2008 | 02:59 PM
kingsey's Avatar
no one?
Old Jan 28, 2008 | 10:33 PM
Formulated's Avatar
I had that cam, and sold it. I kind of regret that to be honest
I would not expect too much of a difference between that cam and a 224/224. It would come down to exhaust system. The 224/230 would work better with cats, or some other restrictive exhaust.
Old Jan 29, 2008 | 02:13 AM
Asmodeus's Avatar
Why do you think that.
Old Jan 29, 2008 | 11:25 AM
kingsey's Avatar
Because it has higher exhaust duration? How far off am I?
Old Feb 2, 2008 | 05:14 PM
ringram's Avatar
Sounds plausable to me
Old Feb 2, 2008 | 11:22 PM
oange ss's Avatar
more exhaust lift/duration will crutch a weak exhaust system...
Old Feb 4, 2008 | 03:14 PM
kingsey's Avatar
and if you have a good exhaust system?
Old Feb 4, 2008 | 05:43 PM
Ryan02SS's Avatar
While the exhaust system plays a role, it's really a factor of how well the exhaust port of the cylinder head flows. If your exhaust port is very efficient and your intake port to ex port % flow is good, alot of the time a single pattern cam is more efficient. As you can see there is alot of depends in choosing a cam and one should be chosen based off the sum of your parts and mainly the flow capability of the cylinder head.
Old Feb 5, 2008 | 02:59 AM
WLDLS1's Avatar
hi guys. im Alan and im from melborne australia. over here i have a vy ss commodore which has the gen 3 5.7 in it. its A4. the engine is stock other than a underdrive pully, otr, 1 3/4 pipes and a nice 224/230 comp cam. mine is 591/585. i also run stock brand new LS6 heads.
has a built auto with a 4200 dominator stallie and 3.9 diff gears.
my car makes 290rwkw on 98 ron fuel. and has run a best time of 11.549@121mph in full weight. {1600kg} i drive it everyday. i would recomend the camshaft without a doubt.
hope this helps.
Old Feb 5, 2008 | 04:31 PM
john563's Avatar
Smile
hope this helps.
nice times you runnin,and welcome to ls1tech
