best LS6 heads regardless of price?
Old Jul 10, 2003 | 08:28 PM
kumar75150's Avatar
Default Re: best LS6 heads regardless of price?
mine did 299 at .500 lift
Old Jul 10, 2003 | 08:43 PM
smash's Avatar
I agree with Visceral.
The differences will be small. All these shops' heads are great. Don't get caught up in the nickel and dime hp/flow differences. Support the vendor you would tend to support outside of just this. Pick the one you want to call if something goes wrong or if you need something else someday.
Old Jul 11, 2003 | 03:36 AM
Messiah's Avatar
I know of a local guy that has done 340@.600 with very god low lift numbers on 6.0 heads.
Old Jul 11, 2003 | 12:19 PM
Fenris Ulf's Avatar
Must be a fun flowbench
Old Jul 11, 2003 | 01:34 PM
TEA Brent's Avatar
I have a new stg 3 port that flows 330/285 @ .600. The cost is $2200 plus cores. These heads flow 300 @ .500.
Old Jul 11, 2003 | 03:42 PM
PurEvl's Avatar
305 at .550 with ls1 heads and stock sized valves once again ls1derful did the work.
Old Jul 12, 2003 | 11:09 AM
Joe Kizzire's Avatar
Resident Grump
My guess is Judson @ SAM would probably be able to do the very best set of LS6 heads if $$$ wasn't an issue and you could talk him into doing you a set.
That's right!!!! I've got some puney little LS1 heads that flow 320@650 and that's where they come from. But like the man said "If you can talk him into doing a set".
Old Jul 12, 2003 | 12:29 PM
C4VetteLS1's Avatar
just remember every flowbench is different, if someone spouts off with "my ls1 heads flow 330" well they could flow 300 on another bench...
