To those with Katech Rod Bolts
How did you go about installing them as far as torquing and loosening? I thought it was somewhere about torque it to 40 then loosen, then re torque to 40 then tighten to 50... I just want to make sure before I do it.
Also, I'm suppose to lube the bolts up prior to installation?
I bought them from a member on here, still in new packaging, and am not sure if they will come with instructions and sequences so I wanted to check with you guys.
Thanks!
Thanks!
