Why - Rockers hit retainers!
But yes the rails are under the rockers.
.180" from the locks to the tip of the valve. Hope this helps.
To me I don't see any other reason for this issue other than my machinist taking too much off the valve tips when he cleaned them up.. I appreciate the measurements for sure, I'd have catastrophe I'm sure if I had the caps sitting on the keepers and didn't realize it.
Thanks guys.. I'll have update on fri-sat and pics if problem persists!
I may just wipe my slate clean, buy a set of new ls6/6.0 heads, bolt them on with my new springs and know that it's going to run right. Not really sure yet, very discouraged by all of this.
Can't blame you for being discouraged, I would be too.
He was not aware that he had a problem. I saw this wear on the retainers when I got home with the heads.
I dont know if the problem was the retainer or locks? But notice how deep the valve stem tip is compared to the retainer. I have a set of Comp titanium retainers for the 918 springs also and they look the same visually side by side, but I have not actually measured them to see if there is a difference in the tapered area where the locks fit.
After I put the heads on I decided to check the clearance between the bottom of the rocker and the outer edge of the retainer, .020-.022. Guess what the spec says .045 minimum. The way I ended up checking the clearance was miking different gauge wires, that was the only way to get an accurate reading.
Long story short I took the heads to another shop, they agreed the first shop really fucked up my valves. I had Ferrea valves installed. Sad to say the possibility was that I could have nuked my new 408 due to some ******** ineptness.
Those retainers look screwed up (not where it was hitting, but the design of them). From the photo's it looks like the valve stem is sitting deep in the retainer.
