Leak down test question
Old Feb 3, 2008 | 09:58 AM
MikeC5Vert's Avatar
Default Leak down test question
Hi,
Instead of turning the crank for each cylinder to make sure the valve is closed, is it easier to just remove the valve covers and loosen up rockers?
That way, it much easier to remove all the plugs as well.
I got a C5 and I don't think I got enough space to turn the crank ... I think
Thanks!
-Mike
Old Feb 3, 2008 | 10:07 AM
BLACK2001SS's Avatar
I think with the right set up with a braker bar with an extension should work might have to remove a cupple things in the way like your air box.
Old Feb 3, 2008 | 10:11 AM
fossil's Avatar
I have removed valve covers and bump engine over to get my cylinders as close TDC as possible. I do not like to loosen my valve train when doing leak down test as it could possible be the cause of compression lost.
Old Feb 3, 2008 | 10:14 AM
87gnx's Avatar
Yep,X2
Old Feb 3, 2008 | 10:28 AM
MikeC5Vert's Avatar
Wow, making sense
Look like I will do this for sure
-Mike
