Port and Polish
Old Feb 3, 2008 | 11:43 AM
93blacktransam's Avatar
Default Port and Polish
Can some one give me some direction on porting and polishing my throttle body such as what i need and steps ......i have searched but cant find really any directions
Old Feb 3, 2008 | 11:46 AM
cookba's Avatar
its a sticky in one of the threads.
Old Feb 3, 2008 | 10:13 PM
stevied916's Avatar
I would stay away from epoxying if you're thinging about it. I did mine and it's having problems with the IAC not being able to control the idle. Every time I enlarge the hole it gets better but still does it. Whenever I have time I'm just going to grind all the epoxy out and just run it ported with no epoxy
Old Feb 4, 2008 | 02:30 PM
GuitsBoy's Avatar
I dont have any problems with the epoxy, but I have a large 7/16 hole.
Just make sure you dont touch where the blade seals against the bore, otherwise itll never seal again.
Old Feb 4, 2008 | 08:19 PM
ae13291's Avatar
the reason for porting a tb is to get rid of that ridge thats in front of the blade! smooth that out as much as possible
Old Feb 5, 2008 | 06:56 AM
teke184's Avatar
try searching again...there are several threads that have been on the top page over the past 2 weeks. try the "external" forum
