hotcam=low vacuum?
Could it be that your 68 Camaro's power brake booster requires more vacuum to operate properly (maybe it is less efficient than newer ones)
I have no idea how many inches of vacuum my car has at idle, but maybe your solution lies in replacing the power brake booster with a new model.
Good luck
Tommy
Sounds like you have a requirement for more vacuum than a 98+ car, since I had great brakes with the Hotcam. Look into one of the cams that has more aggressive ramps, or a 114 LS. The hotcam is a 112. I doubt you will miss any power with 114 instead of 112.
Chris
