Adding in LS6 Yellow Valve Springs to an LS1
Old Feb 7, 2008 | 12:37 AM
SIGNEDFOR4's Avatar
Default Adding in LS6 Yellow Valve Springs to an LS1
2001 Corvette Coupe:
I'm seeing some dyno results that point to some "tired" LS1 valve springs. Several people have suggested I drop in some LS6 valve springs and for the price I might as well.
Any thoughts? I've never done anything like this but am not scared to try. Is there a write up anywhere?
Anything else I need to consider. The car will be getting a retune after of course.
Thanks guys!
Old Feb 7, 2008 | 05:03 AM
vettenuts's Avatar
Swap out the valve seals while you are in there. Also, the best tool is sold by Vinci>>>>>>
This tool will make the swap much easier. Follow the service manual for rocker removal/installation. When you pull the rockers/pushrods, use or make an organizer so they get re-installed in the same location and orientation. Pack the heads with clean rags in case you drop a keeper so it won't go very far especially into the motor.
