cam and spring question?
Old Feb 7, 2008 | 07:01 PM
92slowmaro's Avatar
Default cam and spring question?
i have a torquer v3 cam .644 intake lift. and awhile ago i had bought some .650 lift springs. my question is is that safe enough to run? or should i get teh.660 springs?
Old Feb 7, 2008 | 07:12 PM
blkbird's Avatar
I would get the higher rated springs. Thats too close for my tastes....
Old Feb 7, 2008 | 07:21 PM
405HP_Z06's Avatar
You need .060 minimum clearance from coil bind to maximum lift. Using either the Patriot Gold or Extreme will put you in the safe zone. The Extreme has a higher rate and subsequent over the nose pressure. For aggressive lobes, the higher spring rates are beneficial.
Old Feb 7, 2008 | 07:23 PM
joker_01z28's Avatar
I have a similar question, I have a 228r cam, what kind of springs should I get? (stock heads)
Old Feb 7, 2008 | 07:26 PM
95 Z28's Avatar
I have the Patriots good to .660 on my Futral cam... .646 lift on the cam. For the 20 bucks extra I figured it's well worth it and have a little extra room and be on the safer side.
