MTI r1 cam ?'s
Old Feb 10, 2008 | 08:46 AM
Striped02WS6's Avatar
Default MTI r1 cam ?'s
i have pretty much decided to buy this cam and i have a few questions before i pull the trigger...
1. how streetable is this cam with full boltons and a M6 (cam specs are 232 236 on 114 LSA ...
2. any flycutting required.
other then that i have pretty much decided this is the cam i want...i am also putting on a set of stage 2 patriot LS6 heads in a few months to compliment the cam....how much power will i see with and without the new heads..thanks
Old Feb 10, 2008 | 09:50 AM
no one? from what i have gathered so far the cam is intended for a car with more then 346 CI...however there are bigger cams out there people are using on stock CI...can someone explain that to me....
Old Feb 10, 2008 | 09:58 AM
RGKSR's Avatar
Default 346/MN6 with MT1 R1 Cam
I had this cam in my '00 FRC for a few months. I made 351/314 after ECS tuned it. Lumpy idle, very driveable.
Mods were LS6 intake/Vararam/Dynamaxx headers/Corsa catback/ LS6 heads with minor clean up work. I did not need to flycut with my setup.
The only reason I changed the cam is because I went to a SLP 402.
Bob K.
Old Feb 10, 2008 | 10:24 AM
thanks for replying....the hp and tq numbers you are saying you made seem very low for a cam of its size....i am almost seeing a trend though...anyone else
