LS1 forge rebuild
Old Feb 10, 2008 | 09:59 PM
white99's Avatar
Default LS1 forge rebuild
I'm ready to build the LS1 and make it stronger. The motor has 56xxx on it. I think I may have a rod knock yet the car pulls strong. The feeling I get from the car (can't really hear it) is when I come to a stop. The car will feel a little shaky. It is very light and does it for only a second or so. It's not a misfire. I only get a SES light showing P0440, which is my gas cap not releasing pressure.
So I really don't know if it is rod knock or a bearing. It's not noticeable from outside the car. I did miss 2nd gear on a 150shot with no window switch. According to the hp tuners it made it to 6400rpm.
Well I want to forge the motor. What I am geared towards are:
Eagle crank
Eagle rods
WiseCo pistons
while I'm in there I'll probably change the oil pump as well. A friend recommended I bore for a 3.905 to clean the cylinder walls. What other parts should I get? I really don't know I have a cheater cam now and I'll stick with it for a while but I want to go with better heads. with some more flow. I also want to make more power all motor.
All suggestions & help is appreciated
Old Feb 10, 2008 | 10:01 PM
Kingc8r's Avatar
I believe TSP and Speedinc as well as other's have affordable shortblocks that are forged
Old Feb 11, 2008 | 12:58 AM
Ryan'sSS's Avatar
LME or find a good local machine shop. LME builds quality units. Next best would be to use someone local in case you have any problems.
