quick questions on replacing valvesprings
Old Feb 11, 2008 | 02:15 PM
Striped02WS6's Avatar
Default quick questions on replacing valvesprings
if i get a new set of valvesprings..be it comp 918s, patriot springs or whatever...can i just replace the spring or are retainers, locks, and all the other stuff required? thanks
Old Feb 11, 2008 | 03:21 PM
vettenuts's Avatar
If you had asked only on the 918's then it would be one answer. But the Patriots will require seals/seats/retainers/locks, all of which come with the kit. All must be changed. Guess there is no quick answer, it depends on what you plan to install.
Old Feb 11, 2008 | 04:32 PM
Camaro396's Avatar
Id replace everything. It is not hard to do seats, seals and retainers. Its only another 10 seconds per spring.
